D 17 Brakes
David Kendall
06-27-2003 17:00:14
Although I've not been around allis all that much I have a friend that has a '58 D 17 with brake problems. He's wanting to keep the tractor but some items need attention. Upon asking me about the brakes I had to beg off, not wanting to steer him in the wrong direction. Would the tractor possibly need the brakes adjusted, if so , would it be an internal or external adjustment? If they need to be replaced is that something he can do himself? Also, are these brakes disc, drum or shoe? And are they wet or dry? Any tid-bits of info would be greatly appreciated. Thanks
JMS/MN
06-27-2003 22:06:12
 Re: D 17 Brakes in reply to David Kendall, 06-27-2003 17:00:14
If he has the series one D17, I think the brakes are like the WD45, later ones are disc and drum, but the early ones are just drum. On either side of the top of the differential, there are two covers, remove them and you will see an adjustment bolt- use a 3/4 inch wrench to turn the nut clockwise, to adjust the brakes. beyond that, you might need to replace the shoes and linings. Later models, with the disc and drum, like the Series III, you need to pull the rear axle housings.
gatz
06-28-2003 16:55:41
 Re: Re: D 17 Brakes in reply to JMS/MN, 06-27-2003 22:06:12
The earlier D17s had drum/shoe like JMS said. If they're worn out, replacing them can be done fairly easy without taking anything else apart. Sometimes the anchor pin at the bottom of the brake housing can be a bear to get loose, especially after a lot of years; and may have some grooves worn in them. Best to let soak in penetrating oil prior to attempt.
If the drums need replacing, the axle assembly will have to come off and requires a bit of forethought, a jack, a hoist and some muscle.
I've done this to my dad's tractor in a regular 2-stall garage without too much difficulty.
Might add that after the adjustment(s) have been made per JMS, the pedals can be adjusted too, so that they are even when applying brakes. There is a threaded rod that goes from the "bellcrank" of the pedal to the brake housing. Just romove cotter pin and rotate in/out to adjust.
