D-17's want lift
jon
03-30-1999 17:57:33
I have a gas and a desiel both. niether one will lift what a tractor of there size should lift. If my plows hit hard clay dirt, sometimes you have to back up and get all the presure off. A freind of has a Ford and he says his tractor will come up in the front end. Mine just sits there. I need help(I'm embrassed). Thanks for help.
Free advice
03-31-1999 02:29:56
 Re: D-17's want lift in reply to jon, 03-30-1999 17:57:33
How deep are you plowing? try it at 6 in.
jon
03-31-1999 14:09:18
 Re: Re: D-17's want lift in reply to Free advice, 03-31-1999 02:29:56
I was using that as an example, when I using my HayRoller my gas tractor wont lift the gate like it should. It lifts better than it closes. I tried picking up a regular size horse-drawn graindrill. 3in is as high as it got. So...
Check
03-31-1999 15:47:57
 Re: Re: Re: D-17's want lift in reply to jon, 03-31-1999 14:09:18
Check your hyd. pumps.
Lloyd
04-01-1999 07:47:12
 Re: Re: Re: Re: D-17's want lift in reply to Check, 03-31-1999 15:47:57
This may sound stupid,but have you checked your hydraulic fluid. I beleave its on the right side of the torque tube belowe the fuel tank. The stick by the shifter is for the transmission fluid. P.S. where do you live and will you sell the diesel?
jon
04-02-1999 19:52:04
 Re: Re: Re: Re: Re: D-17's want lift in reply to Lloyd, 04-01-1999 07:47:12
Lloyd, Hey. Good Question, but yes I have and yes they were a little low. So I added maybe a cup to both. It help a little, but they still want lift like there supposed to. Is it maybe a filter? Is it just in the pump? The pump on the gas tractor continues to pump but wont lift. No I think I will keep my desiel tractor. But think I paid a little to much, what do you think. $1400 for it and a 3bottom plow. I live in Bristol, VA
jon
04-02-1999 19:51:19
jon
04-02-1999 19:49:27
