Allis b oil pressure guage
sean
06-26-2003 01:55:01
my oil pressure guage is not showing any oil pressure but i know the guage works fine.
lenard (La.)
06-26-2003 02:26:58
 Re: allis b oil pressure guage in reply to sean, 06-26-2003 01:55:01
I changed the oil&filter in my WD with a napa filter and my oil pressure went to 0.I read in a post awhile back that the napa filters are paper and the oil pressure would drop so I will try an agco one.Hope this helps.
Bryan Smith
06-26-2003 10:11:58
 Re: Re: allis b oil pressure guage in reply to lenard (La.), 06-26-2003 02:26:58
Sandy Lake Impelemtn sent out a message a few months back saying some of a particular AGCO filter for the B/C/CA/WD/etc were made by a different manufacturer and were showing very low oil pressures. AGCO swapped them out if you brough them back in.
Also, make sure you have the 1/8" or 1/4" metal rod standing up in the oil filter. If that rod is gone - and once in a while they come off with the filter when you change it - you won't read any oil pressure. Make sure the rod isn't stopped up, too. AAAnnnddd, make sure you oil pump is primed - some guys have primed one by pouring oil back down the tube that connects to the oil filter housing. If they sit for a while sometimes the oil pump loses prime.
Hope some of that helps ....!
