WD horsepower
Freewheelin
06-25-2003 15:58:10
I bought a 1950 WD from a gentleman a few months back. He had rebuilt the motor a while ago and put in a 45 crank, and cam, and oversized 45 pistons and sleeves. How much more power would this have? Thanks for your info.
wdTom
06-25-2003 17:19:15
 Re: WD horsepower in reply to Freewheelin, 06-25-2003 15:58:10
Probably around 48 to 50
Freewheelin
06-25-2003 18:33:34
 Re: Re: WD horsepower in reply to wdTom, 06-25-2003 17:19:15
Would that be 48 to 50 instead of the factory 34 of a WD?
wdTom
06-26-2003 18:00:35
 Re: Re: Re: WD horsepower in reply to Freewheelin, 06-25-2003 18:33:34
That would be my guess, you made a 45 engine, then added an over bore for a few more cubes and HP.
Bryan Smith
06-26-2003 10:17:43
The WD45 was rated at 43 belt hp (the WD was 34 belt hp as you noted). So 43+ belt hp probably - maybe a little more depending on what "extra" work was done. So compare the 43 hp and 34 hp numbers directly. You'll *really* notice the extra - I did when I would switch between a WD and a WD45 we used to have.
