Allis D-14 starter problems
Tom
06-25-2003 10:01:49
I have a D-14 that the nose cone of the starter keeps breaking. I have gone through 3. The starter still works but something is causing the nose cone to break when I crank the engine then the gears won't engage the flywheel. Any ideas what would cause the nose cones to start breaking. I've had this tractor for about 5 years and have not had any problems until now.
Kevin C
06-25-2003 15:05:06
 Re: Allis D-14 starter problems in reply to Tom, 06-25-2003 10:01:49
Whose replacement castings are you using?
Some of the aftermarket ones may be thin.
Make sure It is in straight and that the securing bolt is torqued up properly, not too much and not too little.
Good luck
Kevin C
