Throttle spring on C
Butch
06-25-2003 09:38:39
My C surges when put under a load. In an earler post someone said to see if there was a small spring on the throttle shaft, there is not. I see the hole in the shaft where it goes but no spring. What I need to know is does the spring pull to open the engine or to idle it down. Thanks, Butch
Rod (NH)
06-25-2003 10:31:09
 Re: throttle spring on C in reply to Butch , 06-25-2003 09:38:39
Hi Butch,
Here's the spring they were talking about. It is called a link spring and is actually an anti-surge spring.
third party image
Here's a picture of the installation. The long loop end (not seen below) is hooked over the upper manifold stud shown, forward of the carburetor. The round loop end is attached through the hole in the carburetor linkage that you saw. The picture is of my '42B but your C should be the same.
third party image
third party image Rod
Butch
06-25-2003 12:12:44
 Re: Re: throttle spring on C in reply to Rod (NH), 06-25-2003 10:31:09
Thanks Rod, a picture is great, now I know what to look for and where to hook it. Thanks again, Butch
Nate in IL
06-25-2003 11:54:06
Is there also such a spring on a WD45?
Nate
JMS/MN
06-25-2003 16:37:55
 Re: Re: Re: throttle spring on C in reply to Nate in IL, 06-25-2003 11:54:06
The spring on the WD45 hangs vertically between the throttle rod and the engine block drain cock. Not very expensive either, also anything similar in size and strength should work to settle it down. Small hook on one end, large hook on the other.
Butch(OH)
06-25-2003 09:44:39
Neither realy, it pulls more or less straight up. Hooks from the hole you found up to a manifold bolt. That spring is availible from AGCO but is purdy high priced aat around $25 depending on dealer mark up.
Butch
06-25-2003 10:26:26
 Re: Re: throttle spring on C in reply to Butch(OH), 06-25-2003 09:44:39
GEE WHIZ, 25$. I think I will find another C, check it out and head to my local hardware store. You have to give AGCO credit thought for still having it thought. Thanks again, Butch
Robert in Md.
06-25-2003 17:27:57
 Re: Re: Re: throttle spring on C in reply to Butch, 06-25-2003 10:26:26
I put a $.79 Briggs-Stration govenor spring on my B. It worked fine.
Butch
06-26-2003 05:01:05
 Re: Re: Re: Re: throttle spring on C in reply to Robert in Md., 06-25-2003 17:27:57
I will run into town today and get one. If it does not work I sure am not out much. Thanks, Butch
