Hi Kenneth, I have a pair (RH & LH) of mounted plows for my '42 B. They are not AC but are an aftermarket plow made by WIARD Plow Co. It is my understanding that there were several plow manufacturers that produced mounted plows for the B during the war years. Your memory of reversing the drawbar lends me to believe you might be thinking of a WIARD since that is what I have to do to mount mine. That's the standard AC B drawbar. The plows made by AC (much more common) do not use the standard drawbar but another arrangement that mounts in that forward drawbar position. If the plow you are looking at is, in fact, a WIARD, it will have the raised letters WIARD cast into the frog. The main frame will also be of a clean rectangular cross section instead of shaped. In addition, the landslide will be cast instead of wrought. Mine were originally a red color rather than an orange. I suspect the AC ones would be the real persian orange (the earlier version). Mine also are manual lift but I suppose they could also have been made for hydraulic lift. The AC ones were available with either manual or hydraulic. Here's a picture of the WIARDS mounted on my B. Note the reversed standard drawbar. Here's a picture of the AC ones mounted on a C (B mount is similar). Note the major difference in lift mechanism behind the tractor seat that is not used for the WIARD mounting. If you think the plow you are looking at is a WIARD, I have some more pictures detailing the plow mounts if that would help you out. You might, however, be remembering a WIARD but are now looking at an AC one. Rod
