Rear end oil, what weight and how much
Jon2
03-30-1999 10:00:37
I have just purchased a WD 45 and the rear end grease was white, meaning water in the oil, don't know what to put back in it, the oil seemed to be to thin for a third member.
clete
03-31-1999 14:55:02
 Re: Rear end oil, what weight and how much in reply to Jon2, 03-30-1999 10:00:37
WD-45 transmission calls for 17 quarts of 80W Final drives (each) 1.75 quarts of 90W
AL
03-30-1999 12:29:08
STRAIGHT 50W IS THE SAME AS 90W AND DOES NOT HAVE THE NEW ADDITIVES THAT WILL DESTROY BRASS OR COPPER IN OLD TRACTORS - ASK AROUND IT IS AVAILABLE
Chad Wink
03-30-1999 18:36:37
 Re: Re: Rear end oil, what weight and how much in reply to AL, 03-30-1999 12:29:08
As a person who has a background in lubrication engineering, I wonder where you came up with the idea that new gear lube will destroy brass and copper? New transmissions still use brass and copper.
AL
03-30-1999 12:27:48
jason
03-30-1999 10:43:30
THE TRANSMISSION DIFFERENTIAL WILL TAKE 80-90
GEAR OIL, AS WELL AS THE FINAL DRIVES OUT BY THE WHEELS. GOOD LUCK!
