AC model B setting valves?
Rob
06-20-2003 15:06:41
What is the correct valve settings? would like to set the valves so to diagnose running problems??
Thanks to all who reply
Rob
Bob D. (La)
06-20-2003 16:09:17
 Re: AC model B setting valves? in reply to Rob, 06-20-2003 15:06:41
Tappet clearance is .010 hot. Hope this helps. I usually add a couple thousandths cold and do final adjustment hot.
Arden
06-23-2003 21:16:09
 Re: Re: AC model B setting valves? in reply to Bob D. (La), 06-20-2003 16:09:17
It is safe to adjust your valves at .012" cold. Old iron grows when hot just like everything else.
Final adjustment hot (normal operating temperature 163*-180*) at .010" just to be sure.
