AC 180
Joe
03-29-1999 19:27:44
Need your help, we got a older AC 180 that keeps running even when we shut off the engine and the pump. I replaced the fuel filters because it was "lugging" and that help. now takes 5-10 minutes to shut off after we turn off the machine? any ideas one guy says we need a new fuel tank? doesnt make sense to me as I just replaced the filter and that should stop it from running not stopping if it was a rusty tank. PS this is a Diesel, Thans
Ted Buisker
03-31-1999 04:35:55
 Re: AC 180 in reply to Joe, 03-29-1999 19:27:44
I have a D-17 that does the same thing. It seems to be something worn internally in the fuel pump. Try closing the throttle rapidly as you pull the fuel shut off, this works on mine. Good luck. TED
Brian
03-30-1999 17:27:52
Joe, check your linkage from the pump to the shut off. If it doesn't quite pull the stop lever on the pump all the way, or if it binds and engine vibration gradually shakes it loose, it can take some time to stop the engine. Hope this helps. Brian
