Auction "C"
Jim Wiebeck
04-13-1998 17:40:48
I just bought a "C" wide and brush hog at an estate auction. The serial numbers are worn off but estimate it at 1948. It has been converted to 12volt. I want to do some PM but need info on oil (nondet?), plugs & coil wires, etc. The manual that came with it is a copy of the original and doesn't contain all the needed info. Can anbody help or steer me in the right direction. Thanks
Nellie
04-13-1998 19:57:58
 Re: Auction "C" in reply to Jim Wiebeck, 04-13-1998 17:40:48
: I just bought a "C" wide and brush hog at an estate auction. The serial numbers are worn off but estimate it at 1948. It has been converted to 12volt. I want to do some PM but need info on oil (nondet?), plugs & coil wires, etc. The manual that came with it is a copy of the original and doesn't contain all the needed info. Can anbody help or steer me in the right direction. Thanks
You must have missed the spirited debate on OILS a few weeks ago.
A rather strong point was made that when your tactor was made they didn't have det. oil. So now that 10w30 etc. are available, it is okay to use them. Spark plugs are Champion J-8 or 45 AC.
