D-17 Gas O-Rings (for sleeves)
d-17 Dude
06-17-2003 20:44:57
Does anyone know how many sealing O-rings go on a D-17 gasoline Allis per sleeve? Is there one for top and bottom or what? I am about to tear one down to put sleeves in it, but I don't have the sealing rings. I can get them but I don't know how many to get. Any help would be great!
Ron
06-18-2003 08:43:28
 Re: D-17 Gas O-Rings (for sleeves) in reply to d-17 Dude, 06-17-2003 20:44:57
While putting the sleeves in, COAT the "O-ring area" with Non-Hardening Permatex, ot Aircraft Sealer....to make sure you don't ever have a leak there...I would coat the bottom of the water jacket at the lower "Webs", to prevent leaks, should one of the webs crack ( as Many, Many have)... Hope you checked the webs between the 1-2 and 3-4 cylinders for cracks... I believe it is mostly caused by shutting down a very hot engine, without letting it cool out.... Like running out of gas...I always give mine a turn or two with the starter, to keep the heat distributed in the sleeves...if i run out of gas, working hard... My .02 worth..!!!
Dave Wi.
06-18-2003 08:20:43
If you got sleeve,piston,ring set they should have been included,its the same engine as WD45,the boys did mine last week.Kit should have sleeves[4], pistons 1/8" over bore [4],wrist pins[4],rubber O rings for sleeves [8],compression rings [12],and oil rings [4]
wdTom
06-18-2003 18:13:09
 Re: Re: D-17 Gas O-Rings (for sleeves) in reply to Dave Wi., 06-18-2003 08:20:43
My WD kit which I put in last winter had two o rings per sleeve, at the bottom. Are 45 different? My parts book shows 8 O rings for WDs, WD45s, and power units.
Dave Wi.
06-18-2003 18:31:25
 Re: Re: Re: D-17 Gas O-Rings (for sleeves) in reply to wdTom, 06-18-2003 18:13:09
Yep,they have 2 O rings at bottom of sleeves WD+WD45 are the same D17+170 are simalar with larger wrist pins and rings.
d-17 dude
06-18-2003 16:00:17
Thanks for the two responses! I have the information that I need.
