Re: Fuel Gauge
Farmer Gene (WI
06-17-2003 10:06:16
Disconnect the wire at the sending unit, the gauge should read empty,if it doesn't the gauge is bad or the wire is grounded out somewhere. Then touch the wire to a good ground, the gauge should go to full. If it reads empty with the wire disconnected and full when you ground the wire then the problem would be in the sending unit.
