Company Logo (800) 853-2651 Shop Now
Wix Oil Filter ?
Thomas
06-16-2003 16:35:58
I went to the parts store and they sell WIX filters I was looking for one for a CA and the one that they had was a paper filter not a coten one I ask if this was one of those ones that messed up the oil presher like the agco ones did he said it wasent has any one tried one or do I need to wory about it I printed the pictur of the filters someone posted but they are out at the farm I dont remember exacly what it looked like to know if it is the same or not I could not find it in the arcives thanks Thomas
Thomas
06-18-2003 13:28:45
 Re: Wix Oil Filter ? in reply to Thomas , 06-16-2003 16:35:58
I figured that was the case but I only rememberd the one about the agco filters untel you said napa and the wix & carqwest have the same part # on the filter the box is diferant that is it
I am not exacly sure but dont the oil split 2 ways one to the filter and back to the pan and one every where else and if the filter dose not have back bresher the oil gose the easy way threw the filter and in the pan insted of every where else Thanks Thomas
steve
06-18-2003 19:22:54
 Re: Re: Wix Oil Filter ? in reply to Thomas, 06-18-2003 13:28:45
yes, only about 15% of the oil is to go thru the filter and back to sump. the rest 85% goes thru the motor and bearings for lube. if you use the paper filter and it has very little restriction, you will get 50% flow thru the filter back to sump, which will cut the circulating pressure down to a few pounds, possibly 0. the cloth packed filter has proper backpressure. make sure the 1/4 inch tube that slides into the filter is present and has the proper two small holes.
WHAT??
06-18-2003 05:12:32
How can the filter drop theoil presure to 0 when the Allis system only filters a portion of the oil the pump is pumping?
Could you please explain.
I know that my father has a WIX on his CA and his B and he has oil pressure. Don't know whether they are paper or not.
kent
06-17-2003 08:00:49
Thomas, It doesn't matter what brand the filter is as long as it is cotton inside. It should have a wooden stick that you pull out before you install the filter. If the filter is a paper mesh, you're oil pressure will be almost zero...don't use the paper filters. I used to use Wix and the ones they made were cotton and worked good. The paper filter that i bought and did not work was Carquest. Thanks, KEnt
Steve in N.J.
06-16-2003 19:55:07
Thomas, Some of the fellows here on the forum said not to use the Napa filters. Napa filters are made by Wix, so I would imagine that the filter would have the same contruction inside as the Napa. The new revised filter apparentely knocks down the oil pressure on the older machines..
Steve/B&B Custom Circuits
don
06-18-2003 17:47:37
 Re: Re: Wix Oil Filter ? in reply to Steve in N.J., 06-16-2003 19:55:07
i had a problem with the wix filters, i could get no oil pressure, i went to agco alis and got one from them and i had good pressure, don,t know what the difference is but i,m going to stick with the agco alis not worth the hassle with the others i had it happened on two of them. don
Latest Ad: Wanted 13x28 power adjust rim for D 17 allis in NE Nebraska [More Ads]
