Need help adjusting WD-45 carb
Ronnie Blair
06-13-2003 20:01:40
I have a 1955 WD-45 that floods out when I start it up. I want to make sure the float level is correct (I think that's the problem, lots of gas pours out), and to adjust the jets. I have the carb off now (it's the MS 464 model). If someone would take the time to explain the correct procedure to set the float level and adjust the jets, I would sure appreciate it. Thanks, Ronnie
Eldon
06-13-2003 21:00:11
 Re: Need help adjusting WD-45 carb in reply to Ronnie Blair, 06-13-2003 20:01:40
FWIW manual says 9/32"
Scott
06-13-2003 20:20:28
turn the top half of the carb over so the float is facing up. With the gasket on, set the float so the now top of it (actually bottom) is 1/4" above the gasket. This should get you where you need.
Also, make sure that there is no gas in the float. If they get a pin hole in them, they won't float.
