WD45 1960?gear on front end
Laura V.
06-13-2003 07:17:27
My dad needs to know if the crank gear on the front end is threaded on or just a pull off. He can't get off.
Aaron
06-13-2003 16:05:28
 Re: WD45 1960?gear on front end in reply to Laura V., 06-13-2003 07:17:27
It should pull off. Just need to thread the set screw all the way out. Sometimes it takes a heavy puller and a heavier hammer to tap it loose.
Aaron
wdTom
06-13-2003 18:18:22
 Re: Re: WD45 1960?gear on front end in reply to Aaron, 06-13-2003 16:05:28
They can be very tight, that's right about the puller, maybe some heat too. You can spoil them by hammering too hard on the back to get them off. Not too much heat though. To get it back on use a pipe several inches long with a cap or plate welded on the end you are going to hit with a hammer. Support the crankshaft under the back side of the front main bearing so as to not be hammering on the full length of the crank. Maybe heat it a bit to get it back on too. Only to 300 or so degrees.
