Wide front off B to a C
Steve Young
06-11-2003 11:16:20
Can you install a adjustible wide front end off a B to a C if you change the mount on the engine?
Please E-Mail.
Dick L Sure
06-11-2003 11:59:37
 Re: Wide front off B to a C in reply to Steve Young, 06-11-2003 11:16:20
The B's, C's, CA's, and the RC's have the same front engine bolt pattern. For that matter the bolt centers on the D-10 thru D-15's are the same. If ya wants ta put a D-15 engine in yall's B, ya just need to put the B flywheel on the D-15 engine. The correct police won't let ya get away with it at the antique pulls. No sence of humor, they think it's cheatin.
Steve
06-11-2003 12:21:37
 Re: Re: Wide front off B to a C in reply to Dick L Sure, 06-11-2003 11:59:37
Thanks. I was thinking that it might work. Have a guy that wants a wide front for his C. I have one off a B thats adjustable.
CHALMERSBOB
06-11-2003 18:35:00
 Re: Re: Re: Wide front off B to a C in reply to Steve, 06-11-2003 12:21:37
YOU WILL NEED TO REMOVE THE PEDESTAL FROM THE FRONT OF THE ENGINE AND INSTALL THE B FRONT END MOUNT. YOU WILL ALSO NEED THE STEERING ROD FROM THE B. REMOVE THE STEERING ARM FROM THE THE GEAR BOX AND REINSTALL IT IN THE LOWER POSITION AS IT WOULD BE ON A B, OR IT WILL STEER BACKWARDS. THEN IT SHOULD WORK
BOB
Dick L Aw Shucks
06-12-2003 08:17:12
 Re: Re: Re: Re: Wide front off B to a C in reply to CHALMERSBOB, 06-11-2003 18:35:00
Ya just took all the fun outa it. I saw a fellow that had his stearing hooked up where it steared backwards ona B ata pull. He drove it all around the show grounds and he thought he had it down pat. Hooked onto the sled and when the tractor started to need attention as it started to pull down he forgot which way to stear ad got cross ways of the sled.
