WD45 Visual Identification
Nate in IL
06-11-2003 09:43:14
What are the main differences between the WD and the WD45 visually? With the exception of the stickers on the side of the cowl.
Nate
Dave Grubb
06-11-2003 11:22:28
 Re: WD45 Visual Identification in reply to Nate in IL, 06-11-2003 09:43:14
The quickest way is the WD45 will have a curved gear shift handle and the engine block will not have a large plate bolted along the right side of the block. You could still have a WD with a WD45 transmisson and WD45 engine. The surest way is to check the serial number near the left brake access cover.
DanD.
06-11-2003 11:43:27
 Re: Re: WD45 Visual Identification in reply to Dave Grubb, 06-11-2003 11:22:28
The last year of production had the curved shifting lever, so that is not a sure way to tell that you've got a WD45. If it's a straight shifting lever, you can say that you've got a WD, however. The WD 45 started at serial number WD146607.
wdTom
06-12-2003 18:07:58
 Re: Re: Re: WD45 Visual Identification in reply to DanD., 06-11-2003 11:43:27
45s had a curved seat beam with a slotted adjustment for the shock. Original radiators had 3 rows of tubes as opposed to 2 for WDs.
