D-19 CARB
Cap Hillen
06-10-2003 20:01:07
I purchased a '63 D-19 and I fear it has the wrong carb. It should be the Marvel-Schebler TSX 848. But mine is only stamped with Marvel-Schebler and no #. The throtle arm has been brazed, possibly to adapt it and the flange on the carb is slightly smaller than the flange on the intake manifold. No matter how far out I turn the power screw it won't put out black smoke. The motor tested very good for compression and I don't want to lean it out and burn a piston. I took the carb apart cleaned it and cut a new gasket for it so I'm sure there are no blocked passages. I'm wondering if it may be too small for the tractor if it has been switched.
