Allis model 160 value looking for price or knowle
marty meredith
06-08-2003 17:19:01
I am looking to buy allis model 160 it has a kelly
600 loader tractor has 2500 hours with a oil leak it is for sale for 5000 and im in a pinch to buy a utility tractor but like everyonr else im broke. I have anthor tractor im looking at its a JD 950 with a 75 loader for 7750 with no leaks and 2250 hours. Im not a trctor person but need it for little dirt jobs in my landscaping perfesion im trying to start looking for any guidance or help thank marty
Mike
07-12-2003 04:43:48
 Re: allis model 160 value looking for price or kn in reply to marty meredith, 06-08-2003 17:19:01
I use a JD 850 with a #75 loader. I use it to mow 3 acres and to landscape with. The tractor performs flawless and will dig but a scraper box is necessary if you are going to work in hard or compact material. 3 days ago I was grading the ditch in front of my house when someone in a cargo van hit the tractor at 60+ mph. The loader it crooked, but everything still works. The van was totaled.
Dave (NE)
06-09-2003 13:04:39
I bought my 160 a year ago for 3,500, although I had to travel 550 miles to pick it up. It had 4,900 hours on it. All of the other 160's I've seen have been for over 5,000, so the one you're looking at with only 2,400 hours and with a loader sounds pretty good. Check the transmission to make sure it doesn't slip out of gear. This model is also noted for needing new brake disc. I repaired that myself, but the disc are only available from Agco and are expensive ($100 a pair). I also have a slight oil leak, but speculate it needs a new valve gasket. All in all, I really like the tractor. Let me know if you have other questions. Dave
