Model C Front Pedestal Lubrication
Mike
06-07-2003 09:15:41
I am rebuilding my Model C front steering pedestal (two wheel, narrow front end). I can not find in my manuals what I am to use for lubrication. I assume I am to use 90 wt. oil.?? Is this correct? Also, should I grease the bearings or is this pointless with the oil?
dave of southwest michiga
06-08-2003 20:34:04
 Re: Model C Front Pedestal Lubrication in reply to Mike, 06-07-2003 09:15:41
Hi Mike,
I did a bunch of work this past winter on my C's narrow front end, and I just added the gear lube without worrying about the bearings (as there did not seem to be any excessive play in the pinion). The gear box on top, I cleaned thoroughly and repacked with a good moly grease. I've had no trouble at all. I think there is an "operator's manual" that I found somewhere in these pages that I ordered that showed all the lube points and what was suppose to be there...
I'm not at home at the moment (southwest Michigan between South Bend, Indiana and St. Joseph/Benton Harbor, Mi., but in Shreveport,La.) so I can't verify which manual, but it sounds like you're doing ok.
Good Luck
Dave
