Timing a WD
Frank
06-03-2003 18:26:11
Is it possible to time a ('49) WD while running using a timing light? If so, how?
Frank
wdTom
06-03-2003 18:42:53
 Re: Timing a WD in reply to Frank, 06-03-2003 18:26:11
hook up light, get under tractor, remove cover plate under bell housing, aim light up into bellhousing, should be able to see marks on flywheel, using center of casting as reference.
Frank
06-03-2003 19:00:28
 Re: Re: Timing a WD in reply to wdTom, 06-03-2003 18:42:53
Thanks for the response. I didn't know if it was possible to do the timing with the engine running, since the manual describes a static method.
