Gas Tank Sealant
Russ Brownell
05-31-2003 15:54:07
Can anyone recommend a good gas tank sealant for my Allis Chalmers B? I need to somehow seal the tank so it doesn't keep rusting. I cleaned out the tank once but the rust keeps flaking and plugging up the screen. Does anyone know how the sealing process works?
Rob (OH)
06-02-2003 06:59:44
 Re: Gas Tank Sealant in reply to Russ Brownell, 05-31-2003 15:54:07
The Caswell sealer system worked VERY well on my "C" and seal the tank so that it looks wet
all the time. As for the comment of the rust being sealed under the sealer and continuing
to work this shouldn't happen. Rust to form requires water and oxygen. When you seal the
tank you use acetone to dry it and the sealer then goes in to seal the metal from getting any
water or oxygen.
Tom Westerfield(KY)
06-01-2003 05:07:14
Here is another vote for the Eastwood process. I've used it twice. Once on a CA 4 years ago. Fuel is still as clean as a whistle. Just finished a C tank.
Scott
05-31-2003 21:33:13
Empty the tank, take it off, get a couple pounds of dry wall screws, and put them into the tank. I've heard of using some diesel fuel to act as a suspension fluid. Shake like you've never shaken before. I've also strapped it to another tractor's rear rim, and driven arround for a while, or just jacked it up and let it run for a while.
If it's not leaking, I hate to use that sealer, because the rust will remain active under that sealer, and keep rusting out the tank.
Dr Cy Kosis
05-31-2003 20:07:42
I recently sealed a 75 year old tractor tank and used a kit available from Eastwood, which is a suppiler for all the classic and antique car folks.
The kit was complete with cleaner, precoat and 2 pints of final coat for about $50 including shipping.
The system was easy to use with easy to understand instructions. All you needed besides the kit was water, some Muratic Acid and some Acetone. It takes up most of an afternoon and 24 hrs to cure the coating though so be patient.
My tank started with 31 holes, some of the pretty big, up to 1/16th inch. The sealer took care of them all with no presealing. Any rust left in the tank was encapsulated in the sealer so now my fuel bowl glass is crystal clear.
It really worked great, so great that I'm ready to tear the other 70 year old tractors tank off and do it to stop the small amount of rust the bowl continually catches now.
The only thing I'd recommend is that if the tank is more than 15 gallons I'd go on and buy an extra pint of the sealer. My tanks 20 plus gallons and I'd like to have coated it thicker even though it doesn't appear to need it. After about 4 months, no leaks, bleeding or break down of the coating is evident. I'm very pleased with the results.
Terry
05-31-2003 18:44:03
I went to the Tractor Supply co. store and bought a sediment bowlkit for a massey...it has a long neck and a screen that give a reserve and it also keeps the rust below the pickup line that extends about an inch and a half above the bottom of the tank...check one out. Terry
Ken/Wa
05-31-2003 18:32:14
I used a product called Kreem, that I got from a motorcycle shop. It said it was good for a 5 gallon tank, but I used it on my B's tank, which is 13 gallons, and it worked fine. It is a kit, and it was either a 2 or 3 step procedure. No more rust. Just follow directions, and coat the entire tank.
Noly
05-31-2003 18:31:17
took my tank off of my 42 WC to the local radiator shop. they sealed it and pressure tested for pin holes for $100.00.
Mike R. in N.C.
05-31-2003 18:26:06
Another work around is to thread a pipe an inch or two up into the tank for it to feed from. Then it won't be picking up all the flakes. Just a thought for ya. Mike
rod
05-31-2003 17:58:29
I used the por 15 tank sealer it worked well for gas and diesel tanks it is two part process one chemical eats the rust other seals tank holding good so far.r
regards
rod
