3 bottom plow
justin from mcd
05-30-2003 08:07:34
how in the world do i hook up my 3 bottom plow with a snap coupler hitch to my WD without a snap coupler but with a straight drawbar my tractor although has the two lift arms for the plow. TIA
Dave Grubb
05-30-2003 12:07:13
 Re: 3 bottom plow in reply to justin from mcdonough ny, 05-30-2003 08:07:34
You will have to convert your tractor to a snap coupler system: 2 lift arm latches, 1 snap coupler bell assembly(hook and spring), 1 release lever and chain. You will then need a snap coupler draw bar.
BushogPapa
05-30-2003 10:19:15
Get a snap-coupler, WITH the snap-releases for the lift arms.....it may save your LIFE....!!! It was a safety feature that let the plow drop completely OFF.... At LEAST get the snap releases for the lift arms. Many farmers were killed, when the cross bolt fell out, letting the plow kick up, crushing the operator....
