AC B tranny growl
Lloyd
05-30-2003 06:46:33
My B model transmission seems a little noisy with the clutch out,how much is normal ? Any ideas to quiet her down? Works great otherwise-
Thanks
Randy-NJ
05-30-2003 11:28:16
 Re: AC B tranny growl in reply to Lloyd, 05-30-2003 06:46:33
My 'B' had the same noise. It was the throwout bearing. I changed the clutch at the same time. I also learned the importance of Blocking the engine when you seperate the tranny. Randy
PS: When I would put the clutch in the noise would go away. Clutch out, the noise returns. After changing the throwout bearing all was quiet.
lloyd
05-30-2003 12:21:22
 Re: Re: AC B tranny growl in reply to Randy-NJ, 05-30-2003 11:28:16
Thanks for the reply,it does sound like it may be the TOB, my clutch is real good, I am going to investigate a little further,maybe there is a grease fitting on the TOB? thanks, I will keep you posted-
wdTom
05-31-2003 13:55:05
 Re: Re: Re: AC B tranny growl in reply to lloyd, 05-30-2003 12:21:22
There is a grease fitting, it is accessed through the hole in the bottom of the bellhousing.
