WD Main thrust bearing
Brad Mehlinger
05-28-2003 16:47:19
greetings.
I've got a problem and found this forum via google. 30 year nechanic, some dealership stuff, mostly import car, the rest domestic auto and light truck. Overhauling my first tractor engine.
Does the block have a dowel to retain the forward thrust bearing via the oil hole ? It is the only bearing shell that does not have an anit-rotation tab.
I am performing this overhaul with the block installed. No problems pulling sleeves or getting the middle and rear main bearings out. The forward thrust bearing shell seems to be positively retained however. I can only effect a very small rotation (a few thou) either way before it stops hard.
thanks in advance.
Prairieman in South Central Kansas
wdTom
05-29-2003 18:47:03
 Re: WD Main thrust bearing in reply to Brad Mehlinger, 05-28-2003 16:47:19
I may be wrong, don't remember for sure , but I think there is a notch or pin in the face of the thrust surface. You should be able to remove the bearing though by pulling it down. Maybe someone else will know.
Prairieman
05-29-2003 19:35:36
 Re: Re: WD Main thrust bearing in reply to wdTom, 05-29-2003 18:47:03
you're correct.
I posted to another board and was advised to remove the timing cover to allow the front of the crank to droop, allowing the bearing to drop below the pin at the top of the bearing shell.
thanks !
