WD45 Seat Shock Spring
Gary U in NJ
05-28-2003 15:08:27
Well, I didn't think it would be this much trouble, but I'm having a heck of a time finding a replacement shock absorber for my seat.
Has anyone replace one recently, and if so where did you get it? I checked with NAPA and the only thing that gets near the ballpark is a gas shock but its not even the right size.
Thanks!
Gary
Greg Soderberg
05-29-2003 19:40:33
 Re: WD45 Seat Shock Spring in reply to Gary U in NJ, 05-28-2003 15:08:27
Gary,
I got the correct shock replacement fromSandy Lake Implement. Cost $30 plus 6.42 S/H. Call and ask for Brenda. 1-724-376-2489. There are two shock models depending on when your tractor was built. She can tell you which one you need by your serial number. Then, put your old coil spring pieces onto the new shock. Perfect!
Gary U in NJ
05-30-2003 03:35:38
 Re: Re: WD45 Seat Shock Spring in reply to Greg Soderberg, 05-29-2003 19:40:33
Outstanding!
Thanks so much for pasing on the info - I'll give them a shout today.
Gary
Dave Grubb
05-29-2003 12:02:15
Another NAPA number that I keep finding is 94005. I don't recall the number I used when I replaced mine, but the spring and retainers swapped over just fine.
Dave Grubb
05-29-2003 11:45:45
I did a search on this site and found a posting that had an NAPA number of LE10002.
Gary U in NJ
05-29-2003 16:40:28
 Re: Re: WD45 Seat Shock Spring in reply to Dave Grubb, 05-29-2003 11:45:45
Dave:
Many thanks for the research! I'll give the numbers a try tomorrow, keep your fingers crossed I can use the luck.
Gary
David Maddux
05-28-2003 18:00:44
This morning I saw one on e-bay at allis chalmers
Gary U in NJ
05-29-2003 16:37:47
 Re: Re: WD45 Seat Shock Spring in reply to David Maddux, 05-28-2003 18:00:44
David:
Thanks for the reply, I really thought that it would be simple to find. Appreciate you help.
Gary
