Surging D-19
steve (Wisconsi
05-27-2003 13:17:41
My gas D-19 surges when under heavy load. I assume that the governor is at fault - the carborator was replaced last year. None of my manuals (parts, owners, overhaul) mentions how to adjust it. Does anyone have any suggestions?
thanks,
Steve
den/southern illinois
05-27-2003 15:22:06
 Re: Surging D-19 in reply to steve (Wisconsin), 05-27-2003 13:17:41
Check the spring on the left hand side as you sit in the tractor/right behind the radiator. I guess it's the governor spring. My brother had the same problem when we replaced a broken spring with one that looked the same...it wasn't. When he got the correct one from Agco, the problem was solved. Hope this helps.
