Change WD to wide front
g walker
05-23-2003 22:46:03
How much of a job is it to change a narrow front end on a WD to a wide front end?
Tony C
05-24-2003 18:04:20
 Re: change WD to wide front in reply to g walker, 05-23-2003 22:46:03
Bolt in operation. Change bolster and front axle. Might have to loosen frame rails a bit. Tony
gwalker
05-25-2003 16:50:21
 Re: Re: change WD to wide front in reply to Tony C , 05-24-2003 18:04:20
Thanks. Is there anything that I should look out for when shopping for a wide front-end? Any inherent problems with them?
Brian G. NY
05-26-2003 07:30:20
 Re: Re: Re: change WD to wide front in reply to gwalker, 05-25-2003 16:50:21
The hole and the pin at the front pivot plate tend to wear because there is no means for lubricating it. The hole and pin can be built up with weld if necessary. Unless you want an exact restoration on a pre 186413 ser. # tractor, you're better off using the later 4 bolt mounting plate unit which will hold up better under heavy use with a loader than the early 3 bolt unit.
