Re: AC B
Cream colored transmission fluid
steve
05-23-2003 19:21:14
THe cream color is from water aroudn the shift boot as you said. when you drain you get 90% of it out. the new oil will look milky, but not near as bad as the original. it cost an extra $10., but after you run it a couple days, drainit out and install new hydraulic-trans fluid. what you drain will look much better than last time, and the new stuff will look real good. To the other question, no, the small amount of water will not hurt anything. Nothing inside to hurt as long as the water level is low and it dont freeze. If you have hydraulics, it can make the parts "stick" and not work so good. changing the oil will always help. Keep the tractor under a roof if possible, or cover with a tarp.
