Location of wd-45 serial #
stuart
05-23-2003 17:35:55
my info. says serial number is on top of left brake housing ..... can't find it ... what's up ???? thanks..... .
JMS/MN
05-23-2003 21:51:43
 Re: location of wd-45 serial # in reply to stuart, 05-23-2003 17:35:55
Very early WDs had the serial number on top. WD45s had the serial number on the rear face of the differential, near the left brake housing. If you are standing BEHIND the tractor, you can see it, If you are looking at it from above, you won't.
wdTom
05-23-2003 17:39:17
Look on the back of the left brake housing, near the top of the machined area. It can be filled dwith paint or rust and difficult to see. Scrape and sand a little on this machined surface and it will probably show. I think some early ones were on the top, maybe even under the cover to the brake area. I am not sure of this though. But it is on the back.
