WD45 only runs 900 RPM
Nate in IL
05-22-2003 19:05:44
I've recently bought a WD45. It will only run up to 900 rpm, the spec is 1699 rpm. What could be wrong. Where to start?
Nate
wdTom
05-23-2003 17:42:14
 Re: WD45 only runs 900 RPM in reply to Nate in IL, 05-22-2003 19:05:44
Don't worry, it will pull the red tractors backwards even so. It probably never had to run faster and doesn't know how. Just kidding, but couldn't resist.
Kevin (FL)
05-22-2003 19:28:46
Nate,
I would try to temporarily disconnect the governor linkage and very carefully, increase throttle manually, watching RPM's. If the engine runs up OK, then you have a governor problem. Might need to be cleaned and freed-up or rebuilt. Also should check timing.
