Whats wrong?
Chuck NH
05-20-2003 18:38:58
Went to install the radiator onto my Allis Chalmers C tonight and the top radiator inlet was almost a third of a hole off (left to right)from the thermostat housing outlet. No way will the upper radiator hose work at that angle. Radiator came off a power unit and appears to be square. The radiator support was also replaced (wanted a good crank hole) and came off a different tractor, but appeared to be nice and straight. I have also rebuilt the engine and front steering support housing. Could it be that the four nuts that attach the front support to the engine need to be loosened to allow some movement to align the upper radiator line? Thanks in advance for your help. Chuck in NH
mojo
05-21-2003 23:35:17
 Re: Whats wrong? in reply to Chuck NH, 05-20-2003 18:38:58
haven't been there specifically, but you're on the right track leaving everything loose til things are lined up (or close enough to go together). just imagine you're in the factory,{1939?} how'd they do it?
been thru the same-finger pinching/kinking/too tight- trouble, still no easy answer. try valesine-won't help but will make the digits feel better! ;-)..... good luck
Tyler(WA)
05-21-2003 09:18:02
If you have the previous radiator, or a bad one, and that tank hole is where you need it... a radiator shop can swap tanks for you.
