Woods mower ca
kent
05-20-2003 05:32:43
thanks for the input on my woods mower problem posted below. both sides of the deck are open, i didn't know there were end caps available. both sides are open with skimmers installed so i'll leave it that way as someone suggested. I guess that will help it from getting clogged. i wonder if that decreases the vacuuming effect though? I guess i should take a blade into the woods dealer and see if I've got medium or high lift blades although they've got a large wing on them already. let me know if any other thoughts, thanks Kent
DAVID
05-20-2003 06:12:07
 Re: woods mower ca in reply to kent, 05-20-2003 05:32:43
I too have a woods mower that was with the "b" I bought recently. I haven't tried it out yet and I have simular questions. On my deck the two outer spindles have left hand threads for blades. All the blades have cutting edges in the same direction(clockwise facing bottom I think). I don't know who had it before to ask if they have
have had trouble. Each blade measures ~20 1/4" across. Also both sides are open with runners.
My concern is the spindles being lefthand thread on two and righthand on one and the blades being all the same. Any ideas? thx. david
Duey (IA)
05-20-2003 19:31:16
 Re: Re: woods mower ca in reply to DAVID, 05-20-2003 06:12:07
David, Replace the odd spindle.....the blade won't stay on if it turnes backward.....won't cut the grass very good either.....might be why it was sold!!!!
DAVID
05-21-2003 10:21:13
 Re: Re: Re: woods mower ca in reply to Duey (IA), 05-20-2003 19:31:16
Duey, you're exactly right on. I am in the process
of trying find another one to match the other two.
Thanks for the feed back. david
kent
05-20-2003 07:38:39
david, it does sound suspicious that one has the wrong thread. i would set on the seat and let the clutch out slowly noting which way the blades are turning. then with the tractor OFF, look under the deck and make sure the cutters are all going the correct direction. maybe the center spindle has been replaced due to wear or something. I did find out from the woods website that my deck is an L59 which means left-hand discharge and accordingly lefthand threaded bolts. I don't like the lefthand discharge and now i realize that i've been mowing in the wrong direction. but truthfully, i've never really noticed grass shooting out of either side very much. my blades measure 19 7/8" across which is shorter than yours so mine may have the wrong blades. I think i'll check my belt for tightness, lower the deck a notch (which i think will make it vacuum better), and mow in the opposite direction as i have been. if that doesn't work, i'll take a blade to the woods dealer and ask for a higher vacuum version and check the blade length. I know this has been a lengthy post but maybe we'll learn something. Thanks, Kent
CWL
05-20-2003 08:33:06
 Re: Re: Re: woods mower ca in reply to kent, 05-20-2003 07:38:39
Kent The blades I bought were the high vacuum type. They are 20 1/4" long according to the information that I ordered them from. There is not a lot of clearance under the deck with the new blades which should help to increase the vacuum. I still have a flat block plate on the right side and a discharge chute on the left. There is also a lot of grass that comes out of the back of the deck. All three of the spindles have left hand threads. The tractor is a narrow front end farmall H. I think that your blades are just too short. If you install longer blades make sure there is enough clearance. Also as you have already noted the blades are for left hand use. Good luck these are damn fine mowers
