Price for WD/WD45 parts tractor
Brandon
05-19-2003 21:01:49
What would be a fair offer I should make on a Wd wd 45 tractor. Appears to be complete. Don't know if the engine runs or not. But it has a wide front and it would look nice on my WD:) Has anyone ever built dual rear wheels for these tractors? I might try to do that as well. Let me know what you think. Thanks
JMS/MN
05-21-2003 21:56:29
 Re: Price for WD/WD45 parts tractor in reply to Brandon, 05-19-2003 21:01:49
Around here you could typically pay about $400 for a WD wide front. And no, no one in the entire universe has ever built dual wheels for a WD. (OK, I lied-just having some fun with you). It is easy to attach duals- you can use J-bolts hooked to the rails, or attach to the four square holes in the wheel- with eye bolts mounted in those holes. You need 28 inch diameter spacer bands to put between the wheels, and four J-bolts per wheel to hold everything together. My first set of duals, when I started farming in '72, were on a D17, with J-bolts hooked to the inner side of the rails, and they worked fine. When I say inner side, I mean the short flat portion, not the curved part that goes from one side of the rim to the other.
Brandon
06-03-2003 19:25:04
 Re: Re: Price for WD/WD45 parts tractor in reply to JMS/MN, 05-21-2003 21:56:29
Thanks for the help guys. I'll offer around that 4-450 range.
Jim in Michigan
05-21-2003 06:25:52
450 bucks and you can have my WD parts tractor, wide front, rebuilt head, 2 bottom plow and all the Horn loader parts that I have with it,,I know a few loader parts are missin...Jim
