Woods mower question on allis ca
kent
05-19-2003 05:59:17
I appreciate the help on the electrical on my other post. I also have a question about the mower deck. This model ca is a narrow front (row crop) with a woods L59 5ft. belly mower. Whenever I get in tall grass...say maybe 8 inches tall, the mower will leave an uncut "stripe" towards the left side. in shorter grass i don't have this problem. The blades are very sharp, i'm mowing fairly slow, and the belt is tight. i can watch the pulleys and they don't slip. I studied it this weekend while mowing and i'm very sure that this is being caused by the front wheels of the tractor crushing the grass. then before the grass can spring back up...the blades skims over the grass not cutting it. I'm certain by the way it's lined up it's not the mower deck wheels but the front wheels of the tractor that are crushing the grass. why it seems to be the left front wheel and not the right i'll never know. Has anyone encountered this before?? Does anyone know of a cure for this? It's terribly annoying. I have the deck set up fairly high too. i would appreciate any suggestions. I would also mention that the deck is being driven off of the side pulley and it is very large so i don't think i can make it spin faster. maybe this is just a charactoristic of using a row crop tractor to mow. Thanks, Kent
Thomas
07-01-2003 13:14:21
 Re: woods mower question on allis ca in reply to kent, 05-19-2003 05:59:17
We had a simular problem after sharpining our blades one of the blades stoped terning fast enough in tall grass to cut it all found out that there are shims that go in there with the blades put one or two in to tighten it up and it fixed it but it also maid a funny noise Thomas
Kevin
05-20-2003 03:43:34
You can get 3 diffrent blades from your wood's dealer, no lift, med. lift, and a high lift. I have a L-59 mounted on a CA with the high lift blades, both end cap,s removed. It does a great job. All blades have the part #s on them. All are still avalable.
David
05-19-2003 19:31:52
In Tall grass you need to take the left side block plate off and install the discharge chute in its place. I Mow with a row crop tractor all the time and it works much better than my wide front.
BWH
05-19-2003 18:07:13
I have the same problem with my CA. I have new blades, new belts and still leaves the same strip. It seems to me that the left blade doesn't turn fast enough to pull the grass back up after the wheels run over it. But that is just a guess.
CW:
05-19-2003 07:07:41
How much are the blades worn? I recently replaced the blades on our H with the same mower. The blades had been sharpened enough times that they no longer had enough overlap. New blades fixed the problem.
kent
05-19-2003 09:33:35
 Re: Re: woods mower question on allis ca in reply to CW:, 05-19-2003 07:07:41
I'll check that right away. the blades are actually in great shape...they look almost new. I wonder maybe if they're the wrong length or something. I'll check the overlap tonight.
CWL
05-19-2003 11:03:32
 Re: Re: Re: woods mower question on allis ca in reply to kent, 05-19-2003 09:33:35
I forgot to mention that I got my blades from www.mfgsupply.com They are part# 15-6432 and cost $9.59 plus freight. I just got them so I can't attest to the quality yet. I cut a test path and they worked great.
kent
05-19-2003 14:08:49
 Re: Re: Re: Re: woods mower question on allis ca in reply to CWL, 05-19-2003 11:03:32
I wonder if I could talk you into measuring the length of one of them for me? then i can tell if mine are right. thanks, Kent
