D15 power director jumps out of gear
Ron
05-18-2003 19:40:41
I'm looking for ideas why my D15 Series II power won't stay in high range. Is this a clutch adjustment problem? It's hard to get accurate measurements as instructed by shop manual, so I've had to guess a little. Should I keep tinkering with the clutch or am I barking up the wrong tree?
rick
05-18-2003 21:08:15
 Re: D15 power director jumps out of gear in reply to Ron, 05-18-2003 19:40:41
Ron check to see the set screw on the bottom of the lever is tight.That is a common problem. I had the same problem with mine and it was the set screw came loose.
Ron
05-30-2003 18:41:29
 Re: Re: D15 power director jumps out of gear in reply to rick, 05-18-2003 21:08:15
Rick, You're a genius! The set screw was loose, just like you suspected. I tightened it and the tractor workes great! Sure was a simple solution, and cheap, too. I'm glad people like you will take the time to pass on knowledge to people like me. Thank you!
Charley
05-19-2003 10:04:30
Yes! Definitely check the set screw. Same thing happened to me too..... .
