Wd allis manifold
steve
05-15-2003 01:44:46
I`ve owned my wd for at least 20 years, i have put at least 3 intake/exhaust manifolds on it in that time.. The gasket`s don`t last long an eventually the heat eats up the manifold.. Does anyone else have this problem?
Does anyone know if theres a heavy duty gasket set out there?
JMS/MN
05-17-2003 11:40:38
 Re: wd allis manifold in reply to steve , 05-15-2003 01:44:46
If the mating surface of the HEAD is not smooth and true, a new manifold and gasket will not fit properly.
Ron
05-15-2003 04:45:50
Might be that you have hade some with bad steel... I always install them, using High Temp silicone rubbed into the gaskets...it seems to last well, and keeps them from fraying out... I have only hade to replace one gasket in 20+ years, and the manifold is fine... I work mine often, and Hard..!!
FWIW..!! Ron.
