WD45 Governor Not Opening Up
NJW in IL
05-14-2003 19:32:00
I just bought a WD45. The engine will not go to full throttle. I can move the throttle on the column to the full open position and I can see that the governor control lever is full open, but the engine will not wind out. If I override the governor on carburetor control arm, the engine will rev. What gives?
Nate
Craig Carey
05-15-2003 04:50:26
 Re: WD45 Governor Not Opening Up in reply to NJW in IL, 05-14-2003 19:32:00
I had this same situtation last year, and mine turned out to be just gunked up from old oil and sitting around..... ..your weights could need replaced..... but putting a flexi hose on a can of carb cleaner and spraying through the oil fill hole towards the distributor might free them up if they are gunked up like mine .....is a heck of alot simpler than tearing the governor housing apart then re-timing it.
Tom Miller
05-15-2003 19:35:07
 Re: Re: WD45 Governor Not Opening Up in reply to Craig Carey, 05-15-2003 04:50:26
The arm on the carb might be loose or worn like what mine was before I fixed it.
