Weight of WD
Don E. Foster
05-14-2003 12:00:33
Need the weight of my WD for a tractor pull. Has fluid in tires. Thanks
JMS/MN
05-14-2003 21:43:58
 Re: Weight of WD in reply to Don E. Foster, 05-14-2003 12:00:33
Approximate weight of a WD45 is about 4400 lbs. Wd is very similar,slightly lighter because of smaller tires, less fluid, etc. For pulling, if you need to be accurate, is there an elevator or fertilizer dealer nearby where you can run it across the scale? Customers, usually no charge, otherwise bring beer money.
