Hand crank dimensions?
Tyler(WA)
05-14-2003 09:45:00
I'm bending up a new hand crank for my 1938 B model. Does anyone have the proper dimensions handy? Thanks in advance.
Kevin (FL)
05-14-2003 12:42:42
 Re: Hand crank dimensions? in reply to Tyler(WA), 05-14-2003 09:45:00
Hi Tyler,
Do you have access to ACAD? I have a B crank but no drawings, but could work one up "in my spare time". Otherwise I can import it a WORD or PPT file.
Tyler(WA)
05-14-2003 13:03:20
 Re: Re: Hand crank dimensions? in reply to Kevin (FL), 05-14-2003 12:42:42
No AutoCAD but all I need are rough dimensions.
A close angle for the lugs would also help but I have one that I think is right but it's for a different model.
Thanks
Kevin (FL)
05-17-2003 06:41:08
 Re: Re: Re: Hand crank dimensions? in reply to Tyler(WA), 05-14-2003 13:03:20
Tyler,
Had a busy week--here ya' go on the hand crank:
Diameter: ~5/8" (I thought it was 3/4", but it's less.)
Long section: 14 1/4" from pulley end to outside of bend.
Offset distance: 8" outside to outside.
Handle length: ~4 5/8" (This one does not have the roller on the crank section.)
To make the bend radius on the crank an 1 1/4" pipe seems to be about right. Weld down a couple of 6" sections of the pipe at the right location. Use a section of welding cable or garden hose to mock it up to get the proper layout.
The pulley end has a slight taper that runs about 1/2" along the rod and it tapers down to about 1/2" on the end.
The "cross pin" is centered 3/4" from the end. It appears to be "flattened" 1/4" perpendicular to the rod and 3/8" along the rod. You might try just using a 3/8" bolt and then pressing it in. Then grind/file the bolt to form the shape. I don't know if that's just from wear or that's how the factory did it. Overall length of the pin is 1 1/4".
Let me know if you need any other details. And when I get the time I'll draw it up for the record.
