D-14 Oil and water mixed
Greg
05-12-2003 18:00:34
When I put oil in it goes to the radiator and the oil pan. When I put water in, it goes to the oil pan. I am trying to figure out if I have a cracked block or if it could be something else before I break down the engine. Any ideas?
rick
05-13-2003 23:25:24
 Re: D-14 Oil and water mixed in reply to Greg, 05-12-2003 18:00:34
Greg-- Id suspect it being your sleeve seals.I had same problem with mine and thats what it was.
Charley
05-13-2003 18:23:20
Might be:
Head gasket
Cracked head
Warped head
Sleeve seals (I would be suspicious of these)
Cracked webs between sleeve bores
Cracked block elsewhere
Improper(Not enough) top end (Deck) sleeve protrusion
Probably no use trying to think on it too long. Might as well spend the time on the inevitable teardown.
steve
05-13-2003 15:32:26
it is hard to find something in common between the water and oil jackets. you might have a freeze plug in the head , under vavle cover that is leaking. if it was head gasket, i doubt oil would go into radiator, except when running. normally the mode of failure is water in the oil.
