Oil for transmission/hydraulic/ 1939B AC
Tom
05-12-2003 06:39:02
Does the same oil work for both? And what type oil is recomended
Tyler(WA)
05-12-2003 09:32:16
 Re: Oil for transmission/hydraulic/ 1939B AC in reply to Tom, 05-12-2003 06:39:02
Allis changed their specs in later years and called for their brand of Tractor Hydraulic Fluid (THF.)
I use the same stuff in all my tractors. It's about 20W, has superior lube and corrosion inhibitors and I can get 5 gal. at Sam's Club for under $15.
WallMart has it too.
Glenn
05-12-2003 09:15:48
Yes. SAE 20W is recommended.
bob
05-13-2003 06:19:16
 Re: Re: Oil for transmission/hydraulic/ 1939B AC in reply to Glenn, 05-12-2003 09:15:48
Why is it that some manufacturers recommend thin (20W) oil and others require something alot thicker? I would think that most all transmissions would require very similar lubrication.
steve
05-13-2003 16:02:46
 Re: Re: Re: Oil for transmission/hydraulic/ 1939B AC in reply to bob, 05-13-2003 06:19:16
the original oil in the transmission of the B was like 90 wt gear lube, like many other tractors. when the installed the hydraulic pump, which uses the same oil sump, the had to change to 20 wt (now trans hydraulic fluid) to get it to pump. you are right, most transmission with gears would like a thicker oil. that plan changes when you start adding oil pumps.
Tom
05-12-2003 14:00:07
Thanks guys, that helped alot.
