Rear Mower for WD45
Nate in IL
05-11-2003 17:26:17
I am buying a WD45 and I want to get a mower on it as cheap as possible. Just mowing 5 acres of waterway and pasture. Doesn't need a fine finish and I want the mower on the rear (not the belly). The tractor has a 2-point and snap coupler. What's the cheapest way to get up and mowing. Ballpark $400.
Nate
Bones Magoo
05-13-2003 17:20:53
 Re: Rear Mower for WD45 in reply to Nate in IL, 05-11-2003 17:26:17
With the snap coupler set up, you are pretty much limited to original AC equipment. There are plenty of 3-Point Conversions out there, and then you could mount about any mower you wanted, rotary, flail, sickle, or finish. With this option, you're probably talking about more than $400 dollars though (3 Pt Conversion + Mower)
Personally, my WD has the 3 Pt Conversion and I am running a 6' Flail Mower which I am thoroughly satisfied with.
Charlie (IA)
05-12-2003 19:45:47
Nate,
I found an old New Idea 5' 3 point for my WD45 at auction... It had been converted with some 1/2" flat stock to fit the "Snap Coupler" which is under the center of the tractor where the drawbar goes in (not the snap "hands" on the lift bars). And it also had lift adapters to go in my "snap hands" and a bar to go to where the upper link on a three point would go with a saddle that straddled the bar between the lfit arms.. ( a poor man's 3 point, I guess) I got the whole works at auction for ~ $400 IIRC... I got lucky, but you may be able to find a three point woods type mower and adapt it yourself... Good luck Charlie
Sid
05-11-2003 19:50:38
I think a rear mount sickle mower, if you can't find an Allis prefferably a twin wheel drive I remember a lot of mowers were rigged up to fit the Wd's in this area and you should be able to get one with a seven foot cutter cheaper than a bush hog type mower.
