Allis B belly mower belt diagram
Bill Pugh
05-07-2003 20:00:14
someone tell me how to run the belt on my b with a belly mower with a belt 20ft long. it wont stay on the way it is routed Thanks
Duey (IA)
05-07-2003 21:22:39
 Re: allis B belly mower belt diagram in reply to Bill Pugh, 05-07-2003 20:00:14
Required info.....brand and model of mower.
Bill Pugh
05-08-2003 06:34:45
 Re: Re: allis B belly mower belt diagram in reply to Duey (IA), 05-07-2003 21:22:39
was told it was a woods but dont know for sure. it has three blades, single pulley on outer blades and a triple pulley on center. has pulley on the side in rear to drive the belt with two adjustable pulleys under drive pulley. all pulleys are v type, not flat. no matter how i put the belt on I end up with a lot of twisting at the drive pulley. thanks Bill
bill pugh
05-08-2003 23:40:30
 Re: Re: Re: allis B belly mower belt diagram in reply to Bill Pugh, 05-08-2003 06:34:45
Thanks to all, I think I can handle it from here got lots of pics and info.
Ron Cook, IA
05-08-2003 22:26:49
I have twists in my belt also. I tried to remove them with no luck. It runs just fine though. I am not sure of the model of my mower, but I think it is an L59 Woods.
Duey (IA)
05-08-2003 20:35:10
Bill,
I e-mailed you the belt install page from my Woods manual. Duey
Kevin (FL)
05-08-2003 07:21:45
Bill,
I'm emailing some B&W photos now that may help a little (they're not the greatest quality) and I'll also look for any color photos I have on file that might help. We have a couple of B's, but so far haven't come across a belly mower to use. We do have a Cub with a mower. I'm told that the B is similar except the Cub PTO runs in the opposite direction as most (or all) other tractors. I can get plenty photos of that one and send too.
DAVID
05-08-2003 10:59:48
 Re: Re: Re: Re: allis B belly mower belt diagram in reply to Kevin (FL), 05-08-2003 07:21:45
Hey Kevin, Could I possibly get a shot of those pictures also? I recently purchased a B with woods belly mower (I think) and also at loss as to how it should be routed. My deck has both sides open for discharge. The blades all cut counter-clockwise but the outer spindles have left-hand threads. Since I don't know who had it before me it may be that they didn't have it right either. Thanks!
rich
08-24-2003 16:54:59
 Re: Re: Re: Re: Re: allis B belly mower belt diag in reply to DAVID, 05-08-2003 10:59:48
I HAVE A ALLIS CHALMER C WITH 6' WOODS BELLY MOWER. THE BELT IS OFF AND HAVE NO DIAGRAM OF THE BELT PATTERN. PLEASE, EMAIL A PICTURE OF DECK OF MOWER FOR REFERENCES. THANKS SINCERELY RICHARD
Eric
05-08-2003 21:04:50
 Re: Re: Re: Re: Re: allis B belly mower belt diagram in reply to DAVID, 05-08-2003 10:59:48
I too have a AC B with a Woods L59 mower. My belt is on and it works but it looks 'weird'. So many twists.... and it won't ride flat in the drive pulley. It always flips on its side. Any belt routing photos would be appreciated.
Thanks,
Eric
Duey (IA)
05-08-2003 20:37:24
David,
Kevin (FL)
05-08-2003 12:13:11
David,
Check your mail. I've got some color photos of various types (1-blade or 3-blade) of mowers too.
DAVID
05-08-2003 13:40:56
 Re: Re: Re: Re: Re: Re: allis B belly mower belt diagram in reply to Kevin (FL), 05-08-2003 12:13:11
Will do. Thanks for the generosity in sharing. David
