47 B running problem
Farmer in the D
05-06-2003 20:53:28
My 47 B started acting up mid lawn this afternoon. It sputtered and popped and would only run with the choke pulled out. Oil pressure is good, temp is fine. Plugs are a little carboned and will be replaced. Whether unrelated or not, you tell me, the Martin carb is showing a brown crusty residue mostly to the front half on the outside. I was running gas with at least 10% ethanol for awhile but this last round should not have it. My bowl was cleaned and I noticed the screen is torn too. What am I looking at here? How hard are these carbs to boil out and/or rebuild?
Tyler(WA)
05-06-2003 21:42:45
 Re: 47 B running problem in reply to Farmer in the Dells (WI), 05-06-2003 20:53:28
They're not hard to rebuild but try cleaning out the jets with a thin wire first. Crud can plug those things up pretty fast.
