Locking washer for Steering bolt on WD
Bill Arneson
05-06-2003 12:54:57
I have a challenge with my WD. Below the steering joint, Located under the frame near the front, I have a removable pin/bolt. I have lost the washer/object that locked this in place. Any idea where I might be able to get this? I have felt the bolt and cannot find a hole or rim. It works lose and I cannot turn the steering until I tap it back in place.
John Rogers
05-09-2003 10:45:24
 Re: Locking washer for Steering bolt on WD in reply to Bill Arneson, 05-06-2003 12:54:57
Bill if that pin is coming out you need to check and see if the hole is eggshaped, if so it needs to be enlarged and a new pin made that fits tight,then take a big hammer ,use a heavy shaft for a backup and really swell the pin in the steering shaft & Ujoint. I never have had much success AT this without removing the engine so I had room to work. Not a fun job but better than having the pin drop out while running in road gear. Hope this helps , John
