D-14 and D-15 Power Steering
JW (NC)
05-05-2003 19:19:15
Will a D-15 power steering unit fit in a D-14?
The D-14 is a wide front and does not have a power steering unit in it now.
If so, any complications or tricks to make it work correctly?
H.B. Hutchens
05-07-2003 14:56:49
 Re: D-14 and D-15 Power Steering in reply to JW (NC), 05-05-2003 19:19:15
Put a 15 unit on my 14, had to grind out a small notch in the side rail, 15 is a little wider, all other major parts bolt on, mine did not have the steel lines that run between the cylinder and control unit that goes into the worm gear so I used reguler hyd. lines. Sure made a difference in my loader operation. Hoppe this helps. H.B.
