What model
John
05-05-2003 17:44:14
When my Dad was young, he had a little Allis Chalmers tractor. It was the cutest little thing. It had all kinds of attachments. it was a narrow front end. if I remember correctly the starter switch was a wire loop that you had to pull to turn it over. would anyone have any idea what model I might be referring to? I would like to find an old one in need of work and restore it for him.
Phil Auten
05-05-2003 18:33:06
 Re: what model in reply to John, 05-05-2003 17:44:14
John,
From your description it almost has to be a C, CA or one of the small D series, D10 or D12. If the sheetmetal was rounded at the corners it would be the C or CA. If the sheetmetal was more squared off, it would be a D10 or D12. Other than those, the only ones I can think of would be a 5015 or 5020, but those would've been pretty new compared to the others.
Phil
wdTom
05-05-2003 17:58:19
We need a little more to go on I think, can you remember anything else? Did it have 3 or 4 speeds? Hydraulics? Did you sit on center or off to the right side of the tractor? Was the engine in the rear, under and behind you? What did you use the tractor for? Maybe if you can think of some of these things some of us here could guess what you used to have. Glad to try.
John
05-05-2003 18:09:25
 Re: Re: what model in reply to wdTom, 05-05-2003 17:58:19
It is not a G and the B looks to big.
steve
05-05-2003 19:47:54
 Re: Re: Re: what model in reply to John, 05-05-2003 18:09:25
push rod for starter, and narrow front end--- it was a model C. the B you talk about is the same size, but wide front. Look at the pictures of the C.
