Transmission
Ron Brogna
05-05-2003 17:35:32
My transmission locks in 3rd gear commonly. We have to remove the gear shift to get the transmission to work again, Does anyone have any idea how to fix this ? Is there a kit that will fix it ? I have heard that there are brass guides which are missing on the shifter gates. Any help would be much appreciated.
steve
05-05-2003 19:56:15
 Re: Transmission in reply to Ron Brogna, 05-05-2003 17:35:32
i am assuming you have a WD or 45. remove the shift lever and look at the attachment pivot pins. probably loose fit. you can get new, or buildup with weld and remachine. appears to be a common problem after 60 years.
